In a cable harness drawing I want a table that details a connector with it's name and [model name], its pins, cooresponding wires attached to the pins, and the coresponding colors associated with the wires. See picture below.
Commands:
pin: mbr.connprm.pin.name
Conductor: mbr.connprm.pin.run.cond.name
Color: mbr.connprm.pin.run.cond.color
This I got from the Creo 2 tutorial class for Cabling, but it never works on any cable I create. Does it requires a certain parameter to be defined in order to link to the table properly? I can link it with other commands but once I use the connprm command it fails to populate
