dimension question...
A.DelNegro
Just wondering if anyone knows what he tolerance spec "e9" means next to
a dimension. I have a customer part with a diameter dimensioned 27e9.
Its metric, so the diameter is 27mm. Just not sure what the tolerance
would be.
Thanx in advance
Tony
5 REPLIES 5
BenLoosli
23-Emerald II
(To:A.DelNegro)
Tony,
It is defined in the ISO dimension standards
Ron
Hi Tony,
The tolerance on your nominal dimension of 27 is -40 to -92 in micron.
Regards, Hugo.
TomU
(To:A.DelNegro)
Small "e" should be for shaft size, not hole size. A "27 e9" shaft would have a valid range of 26.908 - 26.960. A "26 E9" hole would have a valid range of 27.040 - 27.092.
Values were pulled from this page:
A.DelNegro
(To:A.DelNegro)
Thanx everyone for the quick replies. I knew it was an ISO tolerance,
just didn't have the info.
Tony
