Duplicate/Shadow Workplane in Display
KorieCarter
I am having trouble with the display of Workplanes in my Creo/Elements Direct Modeling. It is as if a shadow or copy of the workplane is displayed along with it - the shadow can not be selected and is not a separate plane. I have tried changing all visibility-related settings in the 3D Object area, Viewport settings, Workplane Properties and Show settings as well. I can not get the duplicate to go away and it is very deceiving when modeling - especially since I normally work with many planes at the same time. The number of planes I am seeing is actually DOUBLE what I should be seeing. Does anyone know how to turn OFF this option, assuming that it IS optional?
Korie Carter
Tensor Engineering
10 REPLIES 10
Hello, can you send some image to show us?
ty
i have the same issue, should you have found a solution for this issue?
No - no one ever replied to me or addressed the issue, but it drives me crazy. It is very difficult because I work with models that have over 50 workplanes in them, which means I see 100 of them. Very frustrating.
Looks like a video card issue.
What video card are you using?
Have you tried to update the video card drivers?
I am using an NVIDIA Quadro FX 4800 card. I have tried updating the drivers and even had a new card installed recently. The card does have program-specific settings but I can't seem to find one that applies.
you do not happen to have a environment variable installed called SDPIXELFORMAT with value SOFTWARE?
i can simulate the problem when i set this variable.
are you using the certified driver or the most recent driver. the most recent driver is not necessarily the best!
No, I do not have that environment variable set in Windows 7. I am using the most up to date driver... perhaps I will look for a different one to see if that makes a difference.
Can you swap out the card? Ebay has listings for '4800s for a few hundred dollars. Other cards go for much less, if you just want to try isolating - '1800s for $50. I know this because I had an '1800 that stopped playing video, all else worked. $50 was worth the drop in replacement.
Otherwise, this is a great time to get familiar with layer controls/rules and mapkeys. See? Silver Lining!
I already have swapped out the card. Several of my coworkers have different models of NVIDIA Quadro cards and we are all experiencing the duplicate/shadow work planes.
What do you mean by layer controls and mapkeys?
