Flexibility part and snapshot in drawing
XDN
Hello, how can I make the flexible parts used in snapshots appear in the drawings, for example, the different states of a spring depending on the positions of a mechanism? Thank you
Kotom-Eng
(To:XDN)
I think that you are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
http://kotom.eng.free.fr
Catalina
Moderator
(To:XDN)
Hello @XDN
I have moved your topic to the Creo+ and Creo Parametric - PTC Community discussion board in order to get better reach.
Bets regards,
Catalina
PTC Community Moderator
PTC
