How can I get rid of probe (cursor)
Opyone
Hi
How can I get rid of this yellow cursor (probe)?
Before I had a white cursor very convinient for draging (creating a box to capture stuff)
I cannot create a box to select elements! I have to click one by one every components!?!?!?!?!?!?
Even with F2 it dosent work!
Can I get rid of this thing?
Thank you very much
Are you by any chance using a 3D device such as a space pilot? If so, rezero the device. I have run into this issue more than once and the 3D device tends to be the culprit.
Tom
Creo Element\Direct Modeling 20.6.0.0.0
Thanks for the answer....I am not using anything....
if you you have another idea I am there 🙂
PeterKehoe
(To:Opyone)
One possibility is that you have "pre-selection" turned off. Find the Utility toolbar and make sure that the selection is set to All.
