Hi guys, hope you all are doing well .
Need guidance.
Whenever I enter text in creo .sec file, the triangle border appears and I cannot remove it. And it shows even if I export that file into another format.
Please guide me how to remove it.
I am using creo 10.
Modify the Border Settings:
Go to the Annotation tab.
In the Setup group, click on More.
Select Border in the View section.
Click on the triangle border to modify or remove it.
Check Section Outline Settings:
Sometimes, section outlines can be controlled through the model tree.
Right-click on the section in the model tree and look for options to deactivate or hide the section outline.
Best Regards
nestorg780
