I need to find center of pressure on the attached part. Please help how can I do it.
I have created shell to find cg of hollow part? Is this workaround or I need to do something else to find enter of pressure.
Me poor. Nobody replies to my question.
I thought there are experts here and will answer my question.
Sorry I created this in Creo 4.0
I will make it in Creo 3.0 as well if you want to help.
israr, i can not open this file. make it to step/igs part file
I do not believe anyone here can help you, that is an exceedingly ambiguous question. Center of pressure is an aerodynamic term, and you'll need to determine airfow, direction, air density, etc. This is NOT what Pro/E (creo) does, and this isn't the forum for that.
Did you perhaps mean center of GRAVITY (CG)? Now THAT, you can get in Pro/E, after assigning model material parameters (needed for MOI info, but not CG info)/
