As far as I know, no separate license is required for pro programme. Once I click on Model Intent-->Programme--> Edit Design, it is asking me to check File--->options--->license.
I would like to edit pro programme. Can any one please help me on this?
Thanks and Regards
Ketan
Dear Ketan,
For editing your program............you need Advance assembly extension license. It is the add on of creo parametric.
Dear Ketan,
For part model, you actually don't require an add-on. But it becomes a mandate if you are working with assembly models.
