As per my knowledge Test Cases linked to Test Session in Tests field will not change if the Test Session is moved to In Testing state. That is because TestSession.js trigger sets the Tests As Of date. But I am not sure how Test Cases are prevented from showing the updated information after As of Date. Is there a trigger or in built functionality of PTC?
I am curious to know how this works.
Vikram M
@vikramm please can you confirm which product you are using so your query can be directed to the appropriate team?
Sorry about that.
PTC Integrity 10.6
I didn't get a solution yet:(
