Hi everyone,
In anticipation of ThingWorx 9.0’s biggest feature, active-active clustering, we’d like to provide an architectural overview of a sample active-active configuration and its underlying components. If you haven’t already seen it, we invite you to read our previous Community tech tip, where we introduce the concept of active-active clustering for ThingWorx Foundation, which enables you to:
Now, before we go too deep, we’d like to let you know that you can continue to seamlessly upgrade from previous versions of ThingWorx releases to upcoming ThingWorx 9.0 releases. Previously, you could deploy ThingWorx Foundation in a “single server” mode, and, for a high availability in “active-passive cluster” mode (see here for details). In the ThingWorx 9.0 release and onwards, you’ll be able to continue to deploy ThingWorx Foundation in a “single server” mode and for high availability scenarios via our new “active-active cluster” mode. Please note that active-passive clustering configuration will no longer be supported in ThingWorx 9.0 or onwards.
Let’s start with a quick recap on how the ThingWorx Foundation 9.0 release would look like in single server deployment.
ThingWorx 9.0 Deployed in a "Single-Server" Architecture
Below is a high-level diagram depicting the main architectural layers and components of ThingWorx Foundation deployed in a single server mode.
Deployment Components
Below is a brief summary of all major architectural components and their purpose in the deployment architecture:
The Client Layer
This layer is comprised of everything that connects with, sends data to, and receives content from the ThingWorx platform. It be broken down into two groups:
The Application Layer
This layer is where ThingWorx Foundation and other applications deployed with ThingWorx Foundation reside, such as ThingWorx Analytics, ThingWorx Connection Server, ThingWorx Azure IoT Hub Connector and others. This layer provides connectivity to the client layer, performs authentication and authorization checks, ingests/processes/analyzes content, and reacts to conditions by sending alerts. For a specific ThingWorx Foundation deployment that needs basic device data ingestion, processing and storage, you can setup only ThingWorx Foundation server. In some cases, with large number of device connections, you may want to setup ThingWorx Connection Server with ThingWorx Foundation in a single server for further scalable connectivity.
The Data Layer
ThingWorx Foundation includes several persistence provider implementations that enable you to choose a database option that best fits your use case. A persistence provider enables the connection to a data store and the ability to perform a CRUD operation on that data. See here for more information. Currently, there are two basic variations of persistence providers:
ThingWorx supports H2 (in-memory Database), PostgreSQL, MS SQL Server and AzureSQL as both model and data providers, and InfluxDB as only a data provider. Please see here for model and data best practices.
ThingWorx 9.0 Deployed in an Active-Active Clustering Reference Architecture
Below is a reference architecture diagram for ThingWorx 9.0 with multiple ThingWorx Foundation servers configured in an active-active cluster deployment. Please note that this is only one reference example of how ThingWorx 9.0 can be deployed in an active-active clustered environment. There could be other architectural configurations dependent upon the needs of the specific deployment.
Once you have developed an understanding of the basic architectural components in a single server mode, below are the additional components required to run ThingWorx in active-active cluster mode.
The Client Layer
This will be similar to what has been mentioned in the above single server configuration.
In this layer, if you’re familiar with ThingWorx active-passive cluster configuration, then you may be aware of most of the components used below—with the exception of a new component: Apache Ignite that provides Distributed Caching for the horizontally scalable ThingWorx Foundation servers.
The Data Layer
ThingWorx is largely database agnostic. You can continue to use officially supported persistence providers that you may already be using in your existing deployments based off of ThingWorx 8.X or previous releases. Please look out for an upcoming ThingWorx update as well as enhanced installation documents to help with your upgrade and migration questions with the general availability of ThingWorx 9.0.
Please note that this diagram does not make the distinction between model and data providers; depending on your data ingestion needs, separate model and data providers can be used. As a reminder, all databases should be deployed in a high-availability configuration to help eliminate any single point of failure.
In closing, we can't wait to launch active-active clustering in 9.0 to help you:
If you have any questions about active-active clustering or its architecture, please do not hesitate to reach out!
Stay connected!
Kaya
