This script creates a csv file from the audit log filtered by the User Access category, so dates of when users logged in or logged out.
*** see update below *** Note: The csv file has the same name as the Groovy script and does NOT have the .csv extension . To get the .csv extension, the Groovy script has to be renamed to AuditEntryToCSV.csv.groovy . Suggestions on how to improve this are welcome.
*** Update ***: The download works without the renamed groovy script by returning text instead of an input stream. The script has been modified to illustrate this.
Parameters:
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.Context
import com.axeda.common.sdk.id.Identifier
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.audit.AuditCategoryList
import com.axeda.drm.sdk.audit.AuditEntryFinder
import com.axeda.drm.sdk.audit.SortType
import groovy.xml.MarkupBuilder
import com.axeda.platform.sdk.v1.services.ServiceFactory
* AuditEntryToCSV.groovy
* Creates a csv file from the audit log filtered by the User Access category, so dates of when users logged in or logged out.
* @param days - (REQ):Str number of days to search.
* @param model_name - (REQ):Str name of the model.
* @param serial_number - (REQ):Str serial number of the device.
* @note - the csv file has the same name as the Groovy script and does NOT have the .csv extension . To get
* the .csv extension, the Groovy script has to be renamed to AuditEntryToCSV.csv.groovy .
* @author Sara Streeter <sstreeter@axeda.com>
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
try {
def ctx = Context.getUserContext()
ModelFinder modelFinder = new ModelFinder(ctx)
modelFinder.setName(parameters.model_name)
Model model = modelFinder.find()
DeviceFinder deviceFinder = new DeviceFinder(ctx)
deviceFinder.setSerialNumber(parameters.serial_number)
Device device = deviceFinder.find()
AuditCategoryList acl = new AuditCategoryList()
acl.add(AuditCategory.USER_ACCESS)
long now = System.currentTimeMillis()
Date today = new Date(now)
def paramdays = parameters.days ? parameters.days: 5
long days = 1000 * 60 * 60 * 24 * Integer.valueOf(paramdays)
AuditEntryFinder aef = new AuditEntryFinder(ctx)
aef.setCategories(acl)
aef.setToDate(today)
aef.setFromDate(new Date(now - (days)))
aef.setSortType(SortType.DATE)
aef.sortDescending()
List<AuditEntry> audits = aef.findAll()
// use a Data Accumulator to store the information
def dataStoreIdentifier = "FILE-CSV-audit_log"
def daSvc = new ServiceFactory().dataAccumulatorService
if (daSvc.doesAccumulationExist(dataStoreIdentifier, device.id.value)) {
daSvc.deleteAccumulation(dataStoreIdentifier, device.id.value)
// assemble the response
audits.each { AuditEntry audit ->
def row = [
audit?.id.value,
audit?.user?.username,
audit?.date,
audit?.category?.bundleKey,
audit?.message
row = row.join(',')
row += '\n'
daSvc.writeChunk(dataStoreIdentifier, device.id.value, row);
// stream the data accumulator to create the file
InputStream is = daSvc.streamAccumulation(dataStoreIdentifier, device.id.value)
return ['Content-Type': 'text/csv', 'Content-Disposition':'attachment; filename=AuditEntryCSVFile.csv', 'Content': is.text]
} catch (def ex) {
xml.Response() {
Fault {
Code('Groovy Exception')
Message(ex.getMessage())
StringWriter sw = new StringWriter();
PrintWriter pw = new PrintWriter(sw);
ex.printStackTrace(pw);
Detail(sw.toString())
logger.info(writer.toString())
