Forced Root Cause Monitoring - Create a Popup Mashup
No ratings
This post is part of the series Forced Root Cause Monitoring via Mashups and Modal Popups
To not feel lost or out of context, it's recommended to read the main post first.
  • Create a new Mashup called "rcp_MashupPopup" as Page and Static
  • Save and switch to the Design tab
Design
  • Edit the Mashup Properties
    • Set "Width" to 500
    • Set "Height" to 300
  • Add a new Label
    • Set "Text" to "Something went wrong - what happend?"
    • Set "Alignment" to "Center Aligned"
    • Set "Width" to 230
    • Set "Top" to 55
    • Set "Left" to 130
  • Add a new Radio Button
    • Set "Button States" to "rcp_AlertStateDefinition"
    • Set "Top" to 145
    • Set "Left" to 25
    • Set "Width" to 450
    • Set "Height" to 100
  • In the Workspace tab, select the "Mashup"
    • Click on Configure Mashup Parameters
    • Add Parameter
      • Name: "selectedState"
      • BaseType: NUMBER
    • Click Done
  • Save the Mashup
Connections
  • Select the Radio Button
    • Drag and drop its Selected Value property to the Mashup and bind it to the selectedState Mashup Parameter
    • Drag and drop its SelectionChanged event to the Mashup and bind it to the CloseIfPopup service
  • Save the Mashup
Version history
Last update:
‎Nov 14, 2018 10:35 AM
Updated by:
