If you need to change the used hostname at installation of Thingworx Flow, some manual changes should be done without re-installing Flow.
Basically, hostname for Flow should be changed in the nginx configuration and in Flow modules configuration; whenever you see the hostname used at Flow installation, change it with the new hostname.
Change the following configurations after renaming the ThingWorx Flow server in Windows OS :
Thank you for the article.
It's always good to have such information at hand, because, as is often the case, all of a sudden, someone wants you to have it done yesterday.
One more thought regarding this... I couldn't find a similar article in the Knowledge Base. Don't really care, but as a matter of form, I believe it would be a good idea to have one there.
Thanks for your message, here is an article on this subject: https://www.ptc.com/en/support/article/CS317502
Hope it helps,
Raluca Edu
