Pushbullet is a lightweight notifications platform and can be a way to explore Alerts and Subscriptions
Basically create an an Alert on a property and Subscribe to that Alert
Adding Alert to Property Humidity
Adding Subscription
The PTC-PushBulletHelper is just a generic Thing with a service called PushNotification
var json = {
"body": Message,
"title":"Temperature fault",
"type":"note"
var accessHeader = {
"Access-Token": "o.Hnm2DeiABcmbwuc7FSDmfWjfadiLXx2M"
var params = {
proxyScheme: undefined /* STRING */,
headers: accessHeader /* JSON */,
ignoreSSLErrors: undefined /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: 'https://api.pushbullet.com/v2/pushes' /* STRING */,
content: json /* JSON */,
timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
You can test the Helper PushNotification service
Next you can test the subscription
