Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Having trouble remembering how to get into Flow? How about make /Flow the URL?
Since the Flow environment uses NGINX to front-end the various components that make up Flow, there is a very sophisticated set of rewrites and proxy_pass directives in the NGINX configuration. All you have to do is add another 'location' fragment to the vhost-flow.conf file that will push /Flow over to /Thingworx/Composer/apps/flow:
location /Flow {
rewrite ^/Flow$ $proxy_scheme://$server_host/Thingworx/Composer/apps/flow permanent;
On Linux, the file should be at
/etc/nginx/conf.d/vhost-flow.conf
On Windows, the file should be at
c:\Program Files\nginx-[version]\conf\conf.d\vhost-flow.conf
Test the updated config file with (nginx may not exist in your normal path):
nginx -t
Restart the NGINX service:
Linux (one of these will work depending upon your Linux version):
systemctl restart nginx
service nginx restart
Windows:
Net stop ThingWorxOrchestrationNginx
Net start ThingWorxOrchestrationNginx
-or- use the Services app to restart the service
From this point forward https://yourserver/Flow will take you to ThingWorx Flow's home page.
