Axeda: Email File From Data Accumulator
No ratings
This code snippet finds an uploaded file associated with an asset and emails it to a destination email address.  It uses a data accumulator to create a temporary file.
import org.apache.commons.codec.binary.Base64;
import java.util.Date;
import java.util.Properties;
import java.io.StringWriter
import java.io.PrintWriter
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.data.*
import com.axeda.drm.sdk.device.*
import groovy.json.JsonSlurper
import javax.activation.DataHandler;
import javax.activation.FileDataSource;
import org.apache.axiom.attachments.ByteArrayDataSource;
import com.axeda.platform.sdk.v1.services.ServiceFactory;
import com.thoughtworks.xstream.XStream;
import javax.mail.Authenticator;
import javax.mail.Message;
import javax.mail.MessagingException;
import javax.mail.Multipart;
import javax.mail.PasswordAuthentication;
import javax.mail.Session;
import javax.mail.Transport;
import javax.mail.internet.AddressException;
import javax.mail.internet.InternetAddress;
import javax.mail.internet.MimeBodyPart;
import javax.mail.internet.MimeMessage;
import javax.mail.internet.MimeMultipart;
try {
    Context ctx = Context.create(parameters.username)
    DeviceFinder dfinder = new DeviceFinder(ctx)
    def bytes
    dfinder.setSerialNumber(parameters.serial_number)
    Device d = dfinder.find()
    UploadedFileFinder uff = new UploadedFileFinder(ctx)
    uff.device = d
    def ufiles = uff.findAll()
    UploadedFile ufile
    if (ufiles.size() > 0) {
        ufile = ufiles[0]
        File f = ufile.extractFile()
        def slurper = new JsonSlurper()
        def objects = slurper.parseText(f.getText())
        def bugreport = objects.objects[0].mobj_update[0].bugreport
        String from = "demo@axeda.com";
        String to = "destination@axeda.com";
        String subject = "My file";
        String mailContent = "Attaching test";
        String filename = "payload.tar.gz";
        def dataStoreIdentifier = "FILE-IO-SUB-testing"
        def daSvc = new ServiceFactory().dataAccumulatorService
        if (daSvc.doesAccumulationExist(dataStoreIdentifier, d.id.value)) {
            daSvc.deleteAccumulation(dataStoreIdentifier, d.id.value)
        daSvc.writeChunk(dataStoreIdentifier, d.id.value, bugreport);
        InputStream is = daSvc.streamAccumulation(dataStoreIdentifier, d.id.value)
        Base64 base64 = new Base64()
        ByteArrayDataSource rawData = new ByteArrayDataSource(base64.decodeBase64(is.getBytes()));
        // You need to create a properties object to store mail server
        // smtp information such as the host name and the port number.
        // With this properties we create a Session object from
        // which we'll create the Message object.
        Properties properties = new Properties();
        properties.put("mail.smtp.host","mail01.bo2.axeda.com");
        properties.put("mail.smtp.port", "25");
        properties.put("mail.smtp.auth", "true");
        Authenticator authenticator = new CustomAuthenticator();
        Session session = Session.getInstance(properties, authenticator);
        MimeMessage message = new MimeMessage(session);
        message.setFrom(new InternetAddress(from));
        message.setRecipient(Message.RecipientType.TO, new InternetAddress(to));
        message.setSubject(subject);
        message.setSentDate(new Date());
        // Set the email message text.
        MimeBodyPart messagePart = new MimeBodyPart();
        messagePart.setText(mailContent);
        // Set the email attachment file
        MimeBodyPart attachmentPart = new MimeBodyPart();
        //      FileDataSource fileDataSource = new FileDataSource(file)
        attachmentPart.setDataHandler(new DataHandler(rawData))  //fileDataSource));
        attachmentPart.setFileName(filename);
        Multipart multipart = new MimeMultipart();
        multipart.addBodyPart(messagePart);
        multipart.addBodyPart(attachmentPart);
        // Set the content
        message.setContent(multipart);
        // Send the message with attachment
        Transport.send(message);
catch (Exception e) {
    logger.info(e.message)
    StringWriter logStringWriter = new StringWriter();
    PrintWriter logPrintWriter = new PrintWriter(logStringWriter)
    e.printStackTrace(logPrintWriter)
    logger.info(logStringWriter.toString())
// This class is the implementation of the Authenticator
// Where you need to implement the getPasswordAuthentication
// to provide the username and password
public class CustomAuthenticator extends Authenticator {
    protected PasswordAuthentication getPasswordAuthentication() {
        String username = "";
        String password = "";
        return new PasswordAuthentication(username, password);
static byte[] getBytes(File file) throws IOException {
    return getBytes(new FileInputStream(file));
static byte[] getBytes(InputStream is) throws IOException {
    ByteArrayOutputStream answer = new ByteArrayOutputStream();
// reading the content of the file within a byte buffer
    byte[] byteBuffer = new byte[8192];
    int nbByteRead /* = 0*/;
    try {
        while ((nbByteRead = is.read(byteBuffer)) != -1) {
// appends buffer
            answer.write(byteBuffer, 0, nbByteRead);
    } finally {
        is.close()
    return answer.toByteArray();
Version history
Last update:
‎May 16, 2016 11:11 AM
Updated by:
Labels (2)
