First of all wishing everyone a blessed 2017
So here is a little something that hopefully can be helpful for all you Thingworx developers!
This is a 'Remote Monitoring Application Starter'
Mainly this is created around Best Practices for Security and provides a lot of powerful Modeling and Mashup techniques.
Also has some cool Dashboard techniques
Everything is documented in accompanying documents also in the zip (sorry went through a few steps to get this up properly.
Install instructions:
All files needed are in a Folder called: RemoteMonitoringStarter, this is an Export to ThingworxStorage
Not included, but the application uses the GoogleWidgetsExtension (Google Map)
Note: Screen shots provided at the end.
FullAdmin/FullAdmin
All other users have a password of: password.
NOTE: You may have to Reset your Administrator password using the FullAdmin account.
I also recommend changing the passwords after installing.
