DataShape
Simply put, it represents the data in your model giving your application an in-built sense on how to represent the data in different scenarios. DataShape is defined with set of field definitions and related metadata e.g. DataType. DataShapes are must have (except for ValueStream) when creating entities that deal with data storage i.e. DataTable & Stream. For more detail on DataShapes and the DataTypes see DataShapes in ThingWorx Help Center
Note: See ThingShape : Nuances, Tips & Tricks for ThingShape vs DataShape
Ways to create DataShape
Via the ThingWorx Composer
Via a custom service in ThingWorx
// snippet creating the infotable with the var params = { infoTableName : "InfoTable", dataShapeName : "DemoDataShape" }; // CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(DemoDataShape) var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params); // snippet creating the DataShape using the Infotable queried above which returns the field and the metadata on those fields // DSName used below is created as the Resources["EntityServices"].CreateDataShape({ name: DSName /* STRING */, description: "Custom created DataShape" /* STRING */, fields: result /* INFOTABLE */, tags: undefined /* TAGS */ });
Here's how it'd appear in the Service editor :
DataShape creation with JavaScript service in ThingWorx
Via the ThingWorx Extension SDK
Following example snippet shows the creation and usage of the DataShape while creating custom extension with the Extension SDK
@ThingworxConfigurationTableDefinitions(tables = { @ThingworxConfigurationTableDefinition(name = "ConfigTableExample1", description = "Example 1 config table", isMultiRow = false, dataShape = @ThingworxDataShapeDefinition(fields = { @ThingworxFieldDefinition(name = "field1", description = "", baseType = "STRING"), @ThingworxFieldDefinition(name = "field2", description = "", baseType = "NUMBER") })) })
Note: Refer to the ThingShape : Nuances, Tips & Tricks for Tips & Tricks
Other related reads
