How to create and configure Timers and Schedulers via JavaScript Services
  • Timers and Schedulers can also be created and configured programmatically via custom services.
  • The following service, which can be created on any Thing, will create a new Timer using the following Inputs:
// create new Thing
var params = {
	name: ThingName /* STRING */,
	description: undefined /* STRING */,
	thingTemplateName: "Timer" /* THINGTEMPLATENAME */,
	tags: undefined /* TAGS */
Resources["EntityServices"].CreateThing(params);
// read initial configuration
// result: INFOTABLE
var configtable = Things[ThingName].GetConfigurationTable({tableName: "Settings"});
// update configuration with service parameters
configtable.updateRate = updateRate
configtable.runAsUser = user
// set new configuration table
var params = {
	configurationTable: configtable /* INFOTABLE */,
	persistent: true /* BOOLEAN */,
	tableName: "Settings" /* STRING */
Things[ThingName].SetConfigurationTable(params);
  • This code is an example which could also be used to create a new Scheduler.
  • The configuration table for a Timer has the following attributes:
    • updateRate
    • enabled
    • runAsUser
  • The configuration table for a Scheduler has the following attributes:
    • schedule
    • enabled
    • runAsUser
I have currently a taks where this code is helpful but my quesiton here.
Do we need to set the thingname in the param json? like:
// create new Thing
var params = {
params.name=ThingName; Resources["EntityServices"].CreateThing(params); ....
or is already done in the param definition? Means the input parameter is used . No problem I will test it
