Incoming CSV File Parsing - Populating the Axeda Enterprise
No ratings
These code snippets illustrate parsing CSV files and populating the Axeda Enterprise with data, locations and organizations.  These files are incoming to the Axeda Platform.
Note:  These snippets do NOT handle null values in the CSV due to the lack of a CSV parsing library.  Workaround is to populate empty values with an empty or null signifier (such as a blank space) and test for these on the Groovy side.
Code Snippets:
CSV file to Data Items
CSV file to Location Organization
Script Name: CSV file to Data Items
Description: Executed from an expression rule with file hint "datainsert", takes a CSV file and adds data based on values.
Parameters:
OPTIONAL - only needed for debugging
  1. modelName - (OPTIONAL) Str - name of the model
  2. serialNumber - (OPTIONAL) Str - name of the serial number
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DataItemFinder
import com.axeda.drm.sdk.data.DataValueEntry
import java.util.regex.Pattern
import groovy.json.*
import com.axeda.drm.services.device.DataItemType
import net.sf.json.JSONObject
* CSVToData.groovy
* Executed from an expression rule with file hint "datainsert", takes a CSV file and adds data based on values.
* @note  There must be a column with "model" and one with "serial".  The rest of the columns should be data item names with values
* in the rows. DOES NOT handle null values in CSV.  Workaround is to insert blank spaces in null values and test for those on the Groovy side.
* Solution would be to add a library for CSV parsing such as open csv.
* @params - only needed if NOT executed from expression rule - primarily for debugging
* modelName - (OPTIONAL) Str - name of the model
* serialNumber - (OPTIONAL) Str - name of the serial number
* initialize our global variables
* json = the contents of our response
* infoString = a stringBuilder used to collect debug information during the script
* contentType = the content type we will return
* scriptname = The name of this Script, used in multiple places
def json = new groovy.json.JsonBuilder()
def infoString = new StringBuilder()
def contentType = "application/json"
def scriptName = "CSVToData.groovy"
def root = ["result":["items":[]]]
def columns = []
try {
  Context CONTEXT = Context.getSDKContext()
  def modelIndex
  def serialIndex
  // initialize Model and Device Finders
  ModelFinder modelFinder = new ModelFinder(CONTEXT)
  DeviceFinder deviceFinder = new DeviceFinder(CONTEXT)
  // implicit object compressedFile
  File file = compressedFile.getFiles()[0].extractFile()
/* //begin non-expression rule code, useful for debugging
    File file
    modelFinder.setName(Request.parameters.modelname)
              def model1 = modelFinder.find()
    deviceFinder.setSerialNumber(Request.parameters.serialNumber)
    deviceFinder.setModel(model1)
    def d = deviceFinder.find()
     UploadedFileFinder uff = new UploadedFileFinder(CONTEXT)
    uff.device = d
    def ufiles = uff.findAll()
    UploadedFile ufile
    if (ufiles.size() > 0) {
        ufile = ufiles[0]
        file = ufile.extractFile()
*/ //end non-expression rule code
  file.eachLine {line ->
      def row = line.tokenize(',')
      // set the column headings
      if (columns.size() == 0){
        columns = row
        // find model and serial index, assumes there's a column that has "model" and "serial", otherwise take columns 0 and 1
        def modelpatt = Pattern.compile(/[A-Za-z_\-]{0,}model[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
        def serialpatt = Pattern.compile(/[A-Za-z_\-]{0,}serial[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
        modelIndex = columns.findIndexOf{ it ==~ modelpatt } > -1 ? columns.findIndexOf{ it ==~ modelpatt } : 0
        serialIndex = columns.findIndexOf{ it ==~ serialpatt } > -1 ? columns.findIndexOf{ it ==~ serialpatt } : 1
      // otherwise populate data
      else {
          modelFinder.setName(row.get(modelIndex))
          def model = modelFinder.find()
          deviceFinder.setModel(model)
          deviceFinder.setSerialNumber(row.get(serialIndex))
          def device = deviceFinder.find()
          def assetInfo = [
                    "model": model.name,
                    "serial": device.serialNumber,
                    "data":[]
          row.eachWithIndex{ item, index ->
              if (index != modelIndex && index != serialIndex){
                def dataItemName = columns[index].replace(" ","")
                DataItemFinder dif = new DataItemFinder(CONTEXT);
                dif.setDataItemName(dataItemName);
                dif.setModel(model);
                DataItem dataItem = dif.find();
                if (dataItem){
                    if (item.isNumber()){
                       item = Double.valueOf(item)
                    DataValueEntry dve = new DataValueEntry(CONTEXT, device, dataItem, item)
                    dve.store()
                else {
                    DataItem newDataItem
                        newDataItem = new DataItem(CONTEXT, model,DataItemType.ANALOG, dataItemName)
                    else {
                       newDataItem = new DataItem(CONTEXT, model,DataItemType.STRING, dataItemName)
                   newDataItem.store()
                   DataValueEntry dve = new DataValueEntry(CONTEXT, device, newDataItem, item)
                    dve.store()
                assetInfo.data << [
                        "name": dataItemName,
                        "value": item
              root.result.items << assetInfo
  logger.info(JSONObject.fromObject(root).toString(2))
} catch (Exception e) {
    processException(scriptName,json,e)
//return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(root).toString(2)]
    Processes the contents of an Exception and add it to the Errors collection
    @param json The markup builder
private def processException(String scriptName, JsonBuilder json, Exception e) {
    // catch the exception output
    def logStringWriter = new StringWriter()
    e.printStackTrace(new PrintWriter(logStringWriter))
    logger.error("Exception occurred in ${scriptName}: ${logStringWriter.toString()}")
        Construct the error response
        - errorCode Will be an element from an agreed upon enum
        - errorMessage The text of the exception
    json.errors  {
        error {
            message     "[${scriptName}]: " + e.getMessage()
            timestamp   "${System.currentTimeMillis()}"
    return json
Script Name: CSV file to Location Organization
Description: Executed from an expression rule with file hint "locorginsert", takes a CSV file and adds orgs and locations based on values.
Parameters:
import com.axeda.drm.sdk.contact.Organization
import com.axeda.drm.sdk.contact.Location
import com.axeda.drm.sdk.contact.OrganizationFinder
import com.axeda.drm.sdk.contact.LocationFinder
import com.axeda.drm.sdk.data.UploadedFile
import com.axeda.drm.sdk.data.UploadedFileFinder
* CSVToLocOrg.groovy
* Executed from an expression rule with file hint "locorginsert", takes a CSV file and adds orgs and locations based on values.
* @note  There must be a column with "model" and one with "serial".  The rest of the columns should be either parts of a
* location or an organization.  The location parts columns should be prefixed with the org# that they correspond to.
* DOES NOT handle null values in CSV.  Workaround is to insert blank spaces in null values and test for those on the Groovy side.
def scriptName = "CSVToLocOrg.groovy"
def columns = []
try {
  def modelIndex
  def serialIndex
  def locIndices = [:]
  def locKeys = ["line1","line2", "address1", "address2", "city","state","zip","country", "org"]
  // initialize Finders
  LocationFinder locationFinder = new LocationFinder(CONTEXT)
  OrganizationFinder organizationFinder = new OrganizationFinder(CONTEXT)
    File file
    uff.device = d
    UploadedFile ufile
        ufile = ufiles[0]
        columns = row
        locKeys.each{ key ->
            // construct a regex for each key and create a map for finding/creating
            def locPatt = Pattern.compile(/[A-Za-z0-9_\-]{0,}${key}[A-Za-z0-9_\-]{0,}/, Pattern.CASE_INSENSITIVE)
            def colIndex = columns.findIndexOf{
                    def match = it =~ locPatt
                    if (match){
                        return match?.getAt(0)
            if (colIndex > -1){
                locIndices[colIndex] = key
      else {
          def assetInfo = [
                    "locs":[]
          def locMap = [:]
          def orgName
          def locKey
          def locBool = false // make sure we get some criteria
              if (index != modelIndex && index != serialIndex && item && item != ""){
                  locKey = locIndices[index]
                  if (locKey){
                      locBool = true
                      if (locKey == "address1"){
                        locKey = "line1"
                      if (locKey == "address2"){
                        locKey = "line2"
                      if (locKey == "org"){
                            orgName = item
                      // don't execute if we've got an organization key
                      else {
                          // for finding
                          locationFinder[locKey] = item
                          // for creating (if needed)
                          locMap[locKey] = item
          assetInfo.org
          Organization org
          if (orgName){
              organizationFinder.setName(orgName)
              org = organizationFinder.find()
              if (!org){
                org = new Organization(CONTEXT, orgName)
                org.store()
          Location loc
          if (locBool){
              logger.info("with bool")
            loc = locationFinder.find()
            logger.info(loc?.name)
          if (!loc){
              def line1 = locMap["line1"]
              def name = line1?.replace(" ","")?.replace(/\./,"")?.replace("_","") + "_Loc"
              def line2 = locMap["line2"]
              def city = locMap["city"]
              def state = locMap["state"]
              def zip = locMap["zip"]
              def country = locMap["country"]
              if (line1 && city){
               loc = new Location(CONTEXT,name,line1,line2,city,state,zip,country)
               loc.store()
              if (loc && org){
                  org.addLocation(loc)
                  org.store()
          assetInfo.locs << [
                   "name": loc.name,
                    "line1": loc.line1,
                    "line2": loc.line2,
                    "city": loc.city,
                    "state": loc.state,
                    "zip": loc.zip,
                    "country": loc.country
                   assetInfo.org = [
                        "name": org.name
    json.errors  {
        error {
    return json
Version history
Last update:
‎Jun 01, 2016 11:02 AM
Updated by:
Labels (2)
