Installing InfluxDB and Chronograf in Docker
No ratings
Installing an Open Source Time Series Platform
For testing InfluxDB and its graphical user interface, Chronograf I'm using Docker images for easy deployment. For this post I assume you have worked with Docker before.
In this setup, InfluxDB and Chronograf will share an internal docker network to exchange data.
  • InfluxDB can be accessed e.g. by ThingWorx via its exposed port 8086.
  • Chronograf can be accessed to administrative purposes via its port 8888.
The following commands can be used to create a InfluxDB environment.
Pull images
sudo docker pull influxdb:latest
sudo docker pull chronograf:latest
Create a virtual network
sudo docker network create influxdb
Start the containers
sudo docker run -d --name=influxdb -p 8086:8086 --net=influxdb --restart=always influxdb
sudo docker run -d --name=chronograf -p 8888:8888 --net=influxdb --restart=always chronograf --influxdb-url=http://influxdb:8086
InfluxDB should now be reachable and will also restart automatically when Docker (or the Operating System) are restarted.
Comments
Docker Compose flavor procedure can be found here : https://www.influxdata.com/blog/tips-for-running-the-tick-stack-using-docker/
Version history
Last update:
‎Jan 22, 2019 09:46 AM
Updated by:
