Join us on Feb 24th for Thingworx Mashup 101 - Do's and Don'ts Expert Session
No ratings
We will host a live Expert Session: "Thingworx Mashup 101 - Do's and Don'ts" on February 24th, 13h30 EST.
Please find below the description of the expert session and the registration link.
Expert Session: Thingworx Mashup 101 - Do's and Don'ts
Date and Time: February 24th, 13h30 EST
Duration: 1 hour
Host: Aanjan Ravi - Technical Product Manager
Registration Here: https://www.ptc.com/en/events/thingworx-mashup-101
Description:
This session covers the most common and useful tips about how to correctly use Mashup builder, Widgets and Layouts – and what to avoid -  to create applications with good principles of UI/UX and easier to maintain.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Thingworx Active Active Clustering
This session will cover the main aspects of the High Availability Clustering feature launched with the ThingWorx 9.0 release.
Recoding Link
Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts
This session highlights the key points you should evaluate to properly plan your upgrade to Thingworx 9.
Recording Link
Top 5 items to check for Thingworx Performance Troubleshooting
How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support
Recording Link
Comments
Hi All
Our expert session: Thingworx Mashup 101 - Do's and Don'ts is tomorrow!!! Click the link below to register and remember to talk about it to colleagues that might benefit from its content.
See you there!
Version history
Last update:
‎Feb 21, 2021 02:21 PM
Updated by:
