Learn how to send and receive JSON and XML payloads to SOAP and REST services.
This project will introduce how to create services that can send and receive XML and JSON payloads.
Following the steps in this guide, you will develop services to handle, send, and receive XML and JSON.
We will teach you how to use the ThingWorx Platform to handle REST requests and send payload for external SOAP and REST services.
NOTE: The estimated time to complete all parts of this guide is 60 minutes.
Download the attached JSONXMLEntities.zip from attached files and import it into ThingWorx Composer.
In this tutorial, you will learn how to make and handle requests to live external REST and SOAP services. The entities file provided contains the following files and entities as a completed version of the scenario that will be covered:
| Name | Description |
| JSONRequestThing | Thing with examples of making requests using JSON |
| XMLRequestThing | Thing with examples of making requests using XML |
| JSONHandlerThing | Thing with examples of handling JSON requests and returning organized data |
| XMLHandlerThing | Thing with examples of handling XML requests and returning organized data |
This guide will use services provided by Microsoft Azure. Create a free account to utilize Microsoft Azure Web API services. In order to utilize this web api, obtain a FREE API key from Microsoft Azure Portal using these Microsoft Azure instructions. You are able to use other Web APIs for this guide.
Follow the next steps in order to get started.
Whether making a request to a public web service or sending data to a device running an application, ThingWorx is able to utilize different REST request methods (GET, POST, PUT, DELETE, etc) using the ContentLoaderFunctions Resource. This same resource provides services for XML payloads, but JSON is the default formatting for REST. See the "Sending XML Based Requests" section in this guide for working with XML.
This guide will not explain REST or REST methods, only how to use these REST methods.
To get started, create a Thing using the below steps. You will create new services in this Thing to make REST requests and add a service to help with HTML encoding.
NOTE: Examples of these services can be found in the JSONRequestThing entity, which is provided in the download.
| Name | Base Type | Required |
| query | String | True |
8. Add the following JavaScript to help encode the string and return an HTML friendly string.
try {
var result = "";
if(query) {
result = query.replace(/&/g, "&").replace(/>/g, ">").replace(/</g, "<").replace(/"/g, "'");
} catch(error) {
logger.error("JSONRequestThing.EncodeQueryToHTML(): Error Encoding String - " + error.message);
9. Click Save and Continue to save your changes.
For GET requests to a REST service, you will use the GetJSON service of the ContentLoaderFunctions Resource. This service takes parameters from the proxy information to how to handle SSL issues. All of the parameters are optional. Perform the following steps to create your ThingWorx service to make REST Get requests.
| Name | Base type | Required |
| url | String | True |
| header | JSON | False |
3. In the Snippets section, filter and search for GetJSON.
4. Once you've found GetJSON under the ContentLoaderFunctions section, add it to the editor. You'll see all of the possible parameters for the request. In this example, we'll only set the url and header values.
5. Update the code snippet to include the parameters. Use the below code as a reference.
var params = {
headers: header /* JSON */,
url: url /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
6. Set the Output as JSON.
7. Click Save and Continue to save your changes.
This code will enable REST requests to be sent to an available web service. You will need to include the query string in the URL. In the provided sample, open the JSONRequestThing Thing and check out the JavaScript for the SearchMicrosoftBing service for a more complex example.
Note that you are setting the subscription key needed for a Microsoft Azure request and how to encode raw string input into a query string. Check out the Microsoft Azure documentation of the varying query strings that can be used.
POST and PUT requests are created similarly to GET requests. The methods in the ContentLoaderFunctions Resource is PostJSON and PutJSON. These services include a JSON based paramter titled content. This parameter will allow you to compose the body of the request.
Based on how the REST service is implemented, data will be in the content parameter or the headers parameter. See below for steps on creating a POST request.
| body | JSON | False |
3. In the Snippets section, filter and search for PostJSON.
4. Once you've found PostJSON under the ContentLoaderFunctions section, add it to the editor.
5. Update the parameter object to use the parameters for the service. Keep in mind, there are different ways this can be done. If the URL or the header will always be the same, then save these values as properties on the Thing and add parameters if the URL for this request will need them.
6. Test the new service with a running REST application or use both the GET and POST methods to setup your Azure Active Directory.
In ThingWorx, the DELETE method will be called similarly to the GET method. There will be a number of parameters that can be used and you will need to call the DELETE service of the ContentLoaderFunctions Resource. Follow to below instructions.
A simple test for calling this delete method via Azure, is using the REST service to delete an email template. The URI and parameters can be found in the Azure API.
