3-Newcomer
November 30, 2023
MTConnect driver - Condition types are missing common attributes
  • November 30, 2023
  • 0 replies
  • 505 views
We are checking the possibility of using KepserverEX as connector for several factories containing machinery of different OEM's, and several data-protocols (MTConnect is the most common). In testing we came across a potential blocker.
We are currently relying on some attributes commonly implemented in condition-type dataitems within MTConnect, namely "nativeCode" and "nativeSeverity", but it doesn't seem like these attributes are being picked up by MTConnect driver on triggered conditions?
I am using KEPServerEX v6.15.132.0 in combination with MTConnect driver, and I'm relaying the data through IOT Gateway to an MQTT broker.
Is it possible to pick up and relay nativeCode and nativeSeverity attributes somehow and send these along with the value through MQTT?
