I am connecting Mysql through odbc client. The records in my database table are of 5 rows but the default "Maximum Records to Import " is 3 and not allowing me to increase above this. So in kepserver only 3 out of 5 rows are shown.
Path: Kepserver>Tag Generation Options>Maximum Records to Import
I am doing this in trial version of Kepserver in my system. But in other system this is not the case(also using trial version).
What is this issue?
Sri1
Greetings,
There are no known limitations to the import and this may be unique to your implementation of the software, so please create a ticket so that one of our specialty teams can assist you.
Kind Regards,
Andrew Black
Senior Technical Support Engineer
Greetings,
Kind Regards,
Andrew Black
Hi @Sri1.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community.
--Sharon
