Join Anji Seberino of PTC plus guest speaker Dave Martin (of the Creo Parametric YouTube channel) in Mathcad for Mechanical Engineers, the second of our industry-focused webinar series.
In this one-hour webinar, you'll learn what mechanical engineers use PTC Mathcad for, and why engineering calculation software is a perfect fit for mechanical engineering workflows. You'll watch examples (and be able to download the files involved) of real-life problems solved using Mathcad Prime, and you will also see the awesome integration Mathcad has with 3D CAD software Creo, which will increase your efficiency, reduce errors, and help document your design intent.
We capped off the webinar with a live Q&A session.
You can watch the webinar replay at your leisure!
The webinar happened, and it was great!
The replay (and the files used) is now live on mathcad.com, so check it out.
