"IndustrialGateway" Thing Template Logged Properties Causing Issues.
The "IndustrialGateway" Thing Template has several of its properties logged, which is resulting in our "value_stream" database table getting loaded full of needless data (for our use). Is there a way to turn this off, or is the solution to create a schedule job that purges this data?
This is mostly a problem on our dev environments that are using MS SQL Express.
