Export .SLT files
Fernando_R
Export .SLT files
Hello.
I'm using Creo Elements/Direct Modeling (x64 edition) Revision: 20.1.2.0, and every time I export a SLT file, I need to change the maximum deviation value.
Is there a way to lock these values to create a default parameter?
Creo Elements/Direct Modeling 20.1 User
highway45
(To:Fernando_R)
As far as I know it's not possible to fix these values.
Perhaps you could try to start the function with this code or similar:
stl :parts_assemblies :display-options :dev_distance 0.05 :dev_angle 5.00
Our experience is to let the default values for best results.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
Fernando_R
(To:highway45)
I used your suggestion.
I created a custom command and a button for it, but when selecting the 3D part, the values are updated to "random values."
