Measure an angle between edge and the "envelope"
NR_11857671
2-Explorer
Hello all,
I'm trying to measure an angle between a edge of my object and the line that makes up the envelope.  Does anyone know how to do that?
Hi @NR_11857671,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
AmirMerksamer
(To:NR_11857671)
Please explain about the Envelope you refer to. Is that part of the model? How was it created?
    -amir
I have a model of a truck and around that I have an envelope.  I would like to calculate the angle between the side of the truck and the line of the envelope (the angle that I marked in the red square)
The envelope is just a measurement that we can do in Creo.  It envelops the model and gives the measurements
Good Morning,
I see you're in Creo View. The Envelope measurement is not something that you can use to select geometry from. That is, you can't select the edges or surfaces from the Envelope. Rather, what you'd want to do is create construction geometry at the desired locations. From there you can use the Measure Angle option and select the construction geometry as references.
Matt
Matt Huybrecht
