Mirror feature command
  • June 16, 2022
  • 2257 views
There is no mirror feature command
    Best answer by FriedhelmK
    so you ask questions here to suggest improvements in reality?
    If this is always the case, then it is a waste of time to answer your questions.
    Well, maybe it helps someone else, but then you sould mark it as answered, so that it is seen. 🤔
    And why don't you take the direct way?
    Look at
    "Community Creo Ideas Creo Elements/Direct Ideas"
    and contribute your creativity there.
    But I agree with you. Since the program was taken over from CoCreate by Ptc, it has become a stepchild. â˜šī¸
    Correct, there isn't.
    But you can use the normal available functions for that.
    So make a circular pattern with two features.
    Why are you looking for something specific when something else is available?
    Hello FriedhelmK
    Firstly thank you for your reply.
    In fact, I know how to pattern a feature but this is the long way not the real solution. I think, PTC should add new design commands into Direct version. I have been using this program since 2006, and I can not see any useful module since CoCreate version17.
    Look at
