I'm having a problem with PTC Creo Elements/Direct Modeling 20.5.2.0 : Sometimes I loose the little "cross" next to the cursor resulting in me unable to select anything (see attached files). I tried to close the viewport but nothing changed. The only way to get the cross back is to restart Creo.
I can't find a way to reproduce consistantly the problem. I get this issue 1-2 per week.
I hope someone can help me.
Cheers !
I had such behaviour or similar after changing 3D viewport parallel / perspective.
But a restart was also necessary.
Hi @MR_13244953
Thank you for your question.
Your post appears well documented and has received a response, but no resolution so far. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
