is there a option/way/process to select all hole references in Creo elements/direct modeling in one go to fix fasteners ?
The Creo elements/direct modeling version using is 20.5
Perhaps you could try the tool nº 39 which duplicates parts and sets them into several positions:
http://osd.cad.de/lisp_3d.en.htm#39
Thanks for the reply, Highway45. Let me give you an example: I’ve created multiple holes in a model, and now I need to insert fasteners from the library into all the holes. Ideally, I’d like to select just one hole, and the software should automatically identify all the other holes as references and place the fasteners accordingly. kindly let me know a process/way to go about it.
Hi @RI_10997109,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
