Hello Community members,
Im a new in this community.
Im wrote from Italy and I have a question for your.
Can I converted a file .pkg to .iges, .stp, .pk2, .prt or .assembly ??
Thank you for support.
Enrico.
If you did a search on this site you would find a similar question:
which ultimately suggests looking at this:
https://www.ptc.com/en/support/article/CS134024
One would presume that if a .pkg file can be read into Creo, it could then be output in whatever formats Creo will write.
Just to be sure, what software are you using, Creo+ / Creo Parametric or Creo Elements Direct Modeling ?
Hi @SC_12205882,
Anurag
