sketch child of the frame
AR
8-Gravel
8-Gravel
How can I load a sketch via command line that is placed as a child of the frame?
In my case I would like the "logo" sketch to be placed as a child of the "cart_A3" frame
the command line command to load the sketch is:
sd-am-load-sketch
I' have Creo Elements/Direct Modeling 20.5.1.0
Andrea
This response is edited, as I found a much better way of doing it than my original response.
Code:
(sd-am-load-sketch :file_name file_name                   :position position
                   :owner_type :current-frame
                   :owner owner  <- you do not need this if you set the owner_type to :current-frame.
                   :adjust adjustment)
Since
Code:
:current-frame
is set as the
Code:
:owner_type
, you will not need to fill out the
Code:
:owner field
. That is only used if you want the owner to be a specific view or specific sketch.
Adjustment
Code:
:upper_left
:upper_middle
:upper_right
:middle_left
:middle_middle
:middle_right
:lower_left
:lower_middle
:lower_right
Tom
__________________
Tom Kirkman
Creo Elements/Direct 20.1
Dell Precision 3581
https://www.o-i.com
Creo Element\Direct Modeling 20.6.0.0.0
olivierlp
Community Manager
(To:AR)
Hi @AR  ,
I wanted to see if you got the help you needed. If so, please mark the reply as the Accepted Solution. It will help other members who may have the same question.
Olivier
