Front Counter - Creating Published Documents from Arbortext Content Manager
lfraley
November 11, 2011 at 10:00 AM - 10:30 AM
Register online:  https://www2.gotomeeting.com/register/662546171
Shop Coach: Dmitry Tsarev, Irisoft
Title: Front Counter - Creating Published Documents from Arbortext Content Manager
Abstract:
Connecting Arbortext Content Manager to Publishing Engine can be tricky. Dmitry Tsarev gives you some tips and tricks about making it come together smoothly.
About the Arbortext Monster Garage:
There are a million Uber Geeky things you can do in Arbortext. Arbortext is a mature platform: The entire set of tools works together. Arbortext is open: The entire UI and publishing pipeline is 100% available through a well-tested API. The possibilities are enormous for anyone who wants to do new, interesting, over-the-top things with their product information.
In this web series, we feature the Open API and the geeky things you can do with Arbortext. You?ll find knowledgeable mechanics, here. Put on your shop coat, because here we go?.
0 REPLIES 0
