PTC MathCAD and Workgroup Manager: Implementation in a Multi-Org System
AnnMcGrath
In this presentation, the presenter will review what was done at Kennedy Space Center to deploy and implement PTC MathCAD and PTC Workgroup Manager in a multi-org system. During the presentation the presenter will explain how they configured PTC Windchill to create custom soft-types and object initialization rules for their custom numbering scheme and why they choose these methods.  This presentation will also include how to modify the EPM default soft-type file in the PTC Windchill server codebase folder.  The presenter will also go over the code used in a start up script to initiate PTC MathCAD and PTC Workgroup Manager in the proper order, and also set up the environment variables when running both PTC Workgroup Manager and PTC Creo.  The configuration .ini file the presenter used will also be reviewed to show you how to set up the PTC Workgroup Manager and customized it to their user community.  This presentation will be of interest to administrators trying to create a similar set-up in either a single org or multiple org system deployment.  The big take away will be ideas and best practices learned through implementing this system, and the lessons learned what to do and not to do when setting up this configuration.  Attendees will be exposed to several different sets of code used and that worked well and will hear some limitations on what the software can accomplish when configured this way.
Presented by: Corey Jones, NASA KSC - ESC
See all PTC Live Global 2015 - Mathcad Presentations
0 REPLIES 0
Learn more about PTC/USER
FlexPLM Blog Post
Windchill Blog Post
PTC/USER Global Summit
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
