CAD Dimension Issues when printing
- November 24, 2016
- 2 replies
- 3656 views
While printing the part, the CAD dimensions change to mm, what is the problem with dimensions? The STL and actual CAD are attached below:
I'm assuming you are referring to 3D printing. If so, what application are you using to load the STL? What are it's default units set to? Creo does not change the units while creating STL, so the issue is either with the source CAD file or the 3D printing software.
I just checked the CAD file and it is currently set to INCH. The issue has to be on the 3D printing software side.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
