Takes more than 15 seconds before SigmaTile Status "visible" in ThingWorx Asset Advisor
ptc-6095051
Each time after I modified the value of the value of the SigmaTile's Screen_Control tag, it almost instantly feeds through to the accompanying property on the ThingWorx's Thing (SigmaTile_SenseHat.GW.Screen_Control) in ThingWorx Composer.
However, in the ThingWorx Asset Advisor, it seems that each time after I modified the aforementioned tag it takes more than 15 seconds before the status updates (I continuously hit F5 in the browser).
For the Status, on the SigmaTile Asset, I simply configured:
Warning (1): ("SigmaTile_SenseHat-GW:Channel1.Device1.Screen_Control" = 1)
Running (2): ("SigmaTile_SenseHat-GW:Channel1.Device1.Screen_Control" = 2)
Planned Downtime (3): ("SigmaTile_SenseHat-GW:Channel1.Device1.Screen_Control" = 3)
Unplanned Downtime (4): ("SigmaTile_SenseHat-GW:Channel1.Device1.Screen_Control" = 4)
Why does it take so long before Asset Advisor picks up Status changes?
Tags (1)
