thingworx: fundamentals overview mashup is missing
mgulnac-1
7-Bedrock
Exercise 6 - Build Display Data - the ReflowOvenMonitor is missing in the project.  The directions are to select Mashup "ReflowOvenMonitor" which does not exist in Mashups Browse list.  There is not direction on how to create the mashup.
The ReflowOvenMonitor mashup is imported in Exercise 1, Set Up Environment. However, given this is an overview course, I think the instructions to import it are insufficient. I will put in a maintenance request to fix it.
  • After signing in to ThingWorx as the Administrator, click the Import/Export button on the left sidebar.
  • Select Import.
  • Click Browse.
  • Select W:\TWFD-OVER-Lab-Files\TWFD-OVER-Entities.xml.
  • Click Import.
