Create solid model milling tool
- January 25, 2011
- 1 reply
- 10914 views
I am trying to create a milling tool from a solid model. It is a special shape that I want to make sure cuts correctly. The solid model has 1 feature - Revolve. When I am in a manufacturing file, these are the steps I am taking: click Tools Setup, File, New, Open Tool Library - By Reference... and I choose the solid model. But nothing happens. I remember in training we did this and the model came right up. I think the difference may be that the solid had named dimensions such as length, cutter dia. etc. Do I need to do this with my solid model for it to work? If so, how do I name those dimensions in my solid? Is there anything else I am missing? I have attached the cutting tool file just in case that helps.
Brandon
