Hi all,
I have pcb emn and emp files opened in creo but i am un able to make a 3d model
the same which looked in the allegro
please help
thanks
Hi Raj...
Importing the components is done through the EMP file. The board itself (and the holes) are from the EMN file. Broad space claim is all that EMP file will really give you... usually just blocks of the approximate size and shape of your components.
However, if you want, you can get a really tremendous board layout with real detailed parts by going to www.simplifiedsolutionsinc.com
Try this tutorial... I think it's written for one of the Wildfire versions of Pro/E, but it has some great information that should help you:
http://www.simplifiedsolutionsinc.com/images/Steps_to_create_3D_PCBs_in_ProE.pdf
If you need help after checking out these resources, let me know. I've worked with the gentleman that owns Simplified Solutions and he's very good. He saw a need in the Pro/E market and filled it... now he's expanded to other CAD systems as well.
Hope this helps!
-Brian
Try edit definition of the import feature and see if you can do anything with the import doctor.
You might also try to get a different export file like STP.
thanks but this does not work
may be there is problem with importing from allegro to creo
so what is the right way to import from allegro to creo
Regards
Search this in your help files:
"About Using the Allegro Format"
The help files suggest there are limitations that you are probably seeing and require special attention.
Which version of software are you using?
I am using pro/e creo 1.0
parametric, direct and view
I searched in help but it's not valauble
giving different details
thanks
Sorry, I was assuming you were importing Allegro files but you are importing ECAD files.
Same thing, you need to get very familiar with the About Importing ECAD Databases section of the help files.
Someone else might do this in a regular basis. I am only trying to point you in the right direction.
The more descriptive information you provide and the more references you attach will give you much more detailed help in the forum. I know it is hard sometimes with proprietary data.
As a side note, nothing in PTC help is really helpful in a direct sense. It takes experience to get to the bottom of many of these issues that come up daily.
There is a lot of information in the help regarding ECAD. Getting you through it may require support as well. Nothing guarantees that you will be able to achieve the results you are looking for.
thanks
yah its ECAD files emn and emp format in creo
trying to open these but only broad outline came up
not the components which i wanted to come
I will do more search on PTC help
electrical engineer made pcb in allegro and I need to open in creo means import
importing is done but no component is shown up just their outline
Hi Raj...
Hope this helps!
-Brian
Hi Brian,
thanks a lot
this really helps me
I appreciate your help in solving my problem
thank you for your time
raj
My pleasure Raj. Good luck!
