Adding dimension while drawing
ClemensNader
6-Contributor
Is it possible to type the dimension f.e. on a circle while im drawing it?
Because in Creo 1.0 it was possible when i clicked on the symbol and set the dimension to e.g. "60" it changed it and i could place it on the center for example.
@ClemensNader
When sketching circle weak dimension will appear after placing circle which can modify at any point in time and it was same in previous versions as well. But when sketching Circle in drawing, it will allow to define the radius when creating circle.
@ClemensNader
Dodge
(To:Mahesh_Sharma)
So, there's really no way to type in a length or diameter/radius while I'm drawing a line or a circle? Feels like that should be an easy setting to turn on.
