I’ve noticed something strange. Sometimes when I select a sketch from the model tree or from inside the part model and then right click & pick properties; the properties dialogue box doesn’t open. When I select it & go to the EDIT menu first and then pick properties the box opens fine and I can make the changes. I’ve noticed the same thing with datum planes. WF4.0 m092 - Is it just my setup? Is anyone else seeing this behavior?
Tw
