Inherit sheet parameters
rpieters
Is there a function like dg_inherit or dg_derive which can inherit the parameters like "drawn by" to the Cover sheet and other sheets in the document set.
I have a structure like "Document!<companyname>!Cover" as template for the cover sheet and "Document!<companyname>!Sheet" as template for the other sheets.
In "Document!<comanyname>" I want to have the global parameters for the project and in "Document!<companyname>!Cover" I want to have the parameters extra used on the Cover and in "Document!<companyname>!Sheet" I want the parameters extra used for the sheets, for example "Subject sheet".
I hope someone has a solution.
Tnx ahead.
Rinus
Rinus
I do not have an automated solution out of the box. I believe a custom java function could help. Or you could use the model explorer to change multiple sheet parameters at the same time
Open the Model Explorer, using CTRL select all the design sheet and then edit the parameter value and select apply
Hope that helps
7 REPLIES 7
Hi Rinus...
I'm not quite sure what you're asking here. I'm confused maybe by the way you're describing what you're trying to do. You're saying you want to inherit parameters to the cover sheet and template sheets - but what do you wish to inheriting them from? Also, maybe auto-correct is playing havoc because I don't understand these two sentences:
I want to have the parameters extra used on the Cover and in "Document!<companyname>!Sheet" I want the parameters extra used for the sheets, for example "Subject sheet"]
What do you mean by 'the parameters extra used' ? I'll try to help steer you in the right direction but I am a little lost. Can you clarify your problem so I can try to provide some guidance?
Thanks!
-Brian
Hello Brian,
I'll try to explain.
Within Global Paramaters, you have several "Maps" like Dataset, Document, Component, Connection, Port and Spool, in these maps you can add parameters from the Parameter Pool, you can also make a new subtype under these maps.
Now we have under Document the subtype <Companyname> and under the <Companyname> we have the subtype Coversheet and sheet.
Under the subtype <Companyname> we have the parameters which are used in all the sheets and in the subtype Coversheet I only want the parameters which are variable, now I have all the parameters in both types and not depending are each other
I was wundering if there was a solution to inherit parametervalues from the parameters which are in <Companyname> to the subtype Coversheet.
There are more sulution to get what I want, but I want to now what's more in Creo Schematics
I'll hope you understand now what I meant.
Rinus
Rinus
From what i am understand is you do not want the subtype to inherit all the parent types parameters. And that you also want to set the value of a parameter and make the value global throughout the design. Is my understanding correct?
thanks
Jim
Hello Jim,
Summurized that's what I want. Do you have a solution?
Rinus
Hope that helps
Hello Jim,
Now that you have shown me, I remember it again. I had it in my course and I forgot it.
Thank you for your answer.
Rinus
Just to update this topic, Jim provided a new java class to do excatly what you asked for (and even more)
See this post : Java Function to Populate Version number to design sheets and artifacts
