Hi, we using creo 2.0(M250) on a windows 10.
our hardware spec was below that
graphic : NVIDIA QUADRO M4000
RAM : 32 GB
creo was good working on before upgrade a windows 10.
but after upgrade performance is down.
for example,
3D model rotate reaction was very slowly.
3D model ZOOM reaction was very slowly.
we are using compatibility "Disable display scaling on high DPI settings" in creo properties.
and we deinstall graphic card and reinstall recently version.
but creo2.0 still looks down performance.
someone have same issue in windows 10?
just one solution is that upgrade above a creo 3.0 M140 ?
thanks
Warm Regards,
SeonHo Cha
our customer uses Creo 2.0 M240 on Windows 10 Pro 64-bit on 3 desktop PCs
2x NVIDIA Quadro 4000, driver version 21.21.13.6909 released on 01-Aug-2016, display resolution 1920x1080
1x NVIDIA Quadro 2000, driver version 21.21.13.6909 released on 01-Aug-2016, display resolution 1920x1080
Thanks for your reply.
we'll reinstall graphic card driver
The graphics card driver can no longer be found on the NVIDIA homepage.
could you please send me the graphics card driver?
unfortunatelly I can't send you drivers because I do not have them.
If you ask Google ... nvidia quadro 369.09 driver ... you will get following link (I am not sure if it is secure!)
On https://www.nvidia.com/Download/Find.aspx?lang=en-us&QNF=1 page you can find driver version 369.26 and 369.49. I think you can test them.
Thank you so much for the good information.
But the problem persists.
I'm sorry for telling an unresolved story.
Regards, SeonHo
Regards, SeonHo
try adding following option into config.pro temporarily.
graphics win32_gdi
We change config option 'graphics win32_gdi'.
still trouble..
Watch out for this issue when upgrading from Windows 7 to 10.
This symptom is not seen in a Windows 10 clean installation.
I think it was caused by restoring a file backed up on Windows 7.
So I think I should try again after a clean install (Windows 10).
MartinHanak, thanks for the answer.
Warm Regards,
SeonHo
Hi, I have Creo 2.0 M60, it is keeping crashing when I open it. Do you know Creo 2.0 M60 still work on windows10?
install Creo 2.0 M250.
Hi, could you sent me the link to Creo 2.0 M250 download? Thank you.
you can try https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=ENG .
But I'm guessing you don't have active support ... if this is the case then this page is locked.
Refer to this article CS55934. The answer is NO. You will need to upgrade to M190 to use Creo 2.0 on Windows 10.
