WIldfire 4- Pro-manufacture Parameter Settings?
ptc-2878111
Looking for the CIRC_INTERPOLATION parameter in pro-mfg. Used to be under the menus- NC SEQUENCE SEQUENCE SETUP PARAMETERS (Done) MACHINE WHICHWAYDIDITGO???
Hello Greg, in WF4 it should still be there within the Machine section. Have you found it yet? Which type of sequence are you trying to produce? Thanks, Joel
