how to open creo 2.0 file in wildfire 4.0?
anandan
How could I open or edit a prt file made in creo 2.0 in wildfire 4.0?
dgschaefer
(To:anandan)
You need the GCRI (Granite Cross Release Interoperability) plug in:
http://www.ptc.com/products/granite/gcri/free-download.htm
It allows you to open models from up to 3 releases newer in an older release. There are limitations and the model isn't fully editable as native in the older release. I'm not 100% sure about all the limitations, but you can open it and at least edit it like you would any other import.
LinkedIn
dgschaefer
(To:anandan)
LinkedIn
VladimirPalffy
(To:anandan)
Hi - I have same problem and I have found this information: GRANITE-based Cross-Release Interoperability for Pro/ENGINEER - PTC.com
>> results: it is working for me.
Vladimir
Note: source data you can find in creo2 - creoloadpoint\ptc\Creo 2.0\Common Files\M130\x86e_win64\gcri\readnewermodels.dll
place this file into - ProE WF4 - proeloadpoint\x86e_win64\obj\
Best Regards,
Vladimir Palffy
Mahesh_Sharma
22-Sapphire I
(To:anandan)
Atul,
There is an existing discussion, this may give you some information.
Re: Saving Part File from Creo 2.0 to Pro/E 4.0
