Pro Gurus,
Background (most from Joel Nelson, Feb 2007)
I am trying to setup material files that can be read into drawing
format.
With WF3 this can be done IN TWO WAYS:
1. If I require a parameter in my model I can follow TAN 130467 (copied
below for reference)
2. I can just add PTC_MATERIAL_NAME parameter to my format
Either way works fine
However, the problem I am coming across is that material file names can
not have spaces in them, so the file name can not look like:
ALUM ALLOY 5052-H32 PRT ASTM B209
It must look like this:
ALUM_ALLOY_5052-H32_PER_ASTM_B209
And using PTC_MATERIAL NAME will show the second example.
The way to solve this problem is to modify each material file which
provides a PTC parameter "ptc_material_description". Use that field for
your desired descriptive text. The parameter "ptc_material_description"
is reserved and belongs to the material file. In a part model, if only
one material is assigned to that part, create a "material_desc"
parameter and then this relation in the
part.....material_desc=material_param("PTC_MATERIAL_DESCRIPTION") then
in the drawing title block use &material_desc to report the material
description of the model on the drawing.
Now if I follow idea 1 above (Tan 130467), then it causes all of our
users to manually go into the Relation editor and after many mouse
button clicks to pull the "PTC_MATERIAL_DESCRIPTION" parameter into a
relation for each part file. They have to do this manually each time.
I can set up a mapkey so it is a little easier to do, but that can be a
little unstable depending upon where your cursor is prior to running the
mapkey in the Relation editor. Does anyone have a better/different way
to automatically define the material, density, and put into the drawing
format automatically?
TAN 130467
Description
In the new Edit> Setup>Material interface of Wildfire 3.0, User Defined
material parameters are allowed.
However these material parameters cannot be used in relations using the
old syntax <part_param>=MATERIAL_PARAM("<mat_param>", "<mat_name>") as
defined in (
the word ## must be replaced by the actual material ID number. To
retrieve it, the user must select #Insert, #From List #Material in the
Relations dialog box. Then the desired parameter can be selected
visually and then the desired relation line can be added manually.
Madhav Rao
DRS C3 Systems, Inc.
120...
