Plastic Injection Simulation Software
Regular Member
Is anyone using a software product called "Simpoe" and if so is there
any feedback you would be able to provide me with?
They appear to have a solution called "SimpoePro" which can be embedded
into the PTC Creo Elements/Pro graphic user environment.
Hello Robert,
Simpoe developed the new functionality this year, which can display
simulation result in ProENGINEER graphic window.
They web site is as following:
RE: Plastic Injection Simulation Software
Hi Robert,
You may also want to check out Moldex 3D, they toohave the ability to perform molding analysis directly in Wildfire, Creo Elements/Pro as well as Creo Parametric. My previous employer uses it daily with great success. I was personally involved in a product program wheresevere warp was revealed and we wildly altered themodel we used in the mold design. (6MM worth of warp was developed in the mold)The resulting molded part was within dimensional spec first shots from the mold. Very impressive.
