drive shaft mechanism
amedina
Has anyone done a u-joint drive shaft mechanism? We are having problems
with the pro/mechanism sort of drifting. I would be interested in any
input you guys may have about this. We put together a drive shaft with
two u-joints the input is free to rotate. The whole shaft can be
rotated using the mouse. However when we put it in mechanism and drive
the input with a servo motor, the run seems to stop almost at the very
beginning. Almost as if the mechanism drifted its connections apart
through the rotation process.
Any ideas?
alfonso
Alfonso Medina O.
Mechanical Engineer
0 REPLIES 0
